Rear End Leak????
Old Apr 9, 2001 | 09:01 AM
CloudIROCZ28's Avatar
Rear End Leak????
I have rear end leak near the left wheel and it's just a lil bit of oil that's being caked on but how would I go about fixing this and what is the problem??? I have posi- and 3.23 gears.
IROC-Z
G92, LB9 305 TPI, 3.23
Old Apr 9, 2001 | 09:16 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The outer bearing seal on that side is probably shot. All you need to do is drain the fluid and take the axle out. Using the splined end of the axle use it to pry the seal out. Then press the new one in. Those are VERY general instructions. Email me or someone else will probably chime in.
  • 89 Formula 305 WS6
    SFC's
    LCA's
    Spohn Panhard Bar
    Air Foil
    Flowmaster Cat Back
    Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? HA! Its A Rice Burner!
Old Apr 10, 2001 | 07:15 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yup, rip the old seal out, clean the bore good. Smear a little silicone or loc-tite on the outside of the new seal and tap it in. Use a big pipe, a seal tool or a block of wood to hit it in square. If the seal went bad there might be a chance the outer axle bearing is bad too.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
