Differant 700R4's?
Old Apr 10, 2001 | 07:38 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Differant 700R4's?
What's the differance between a 700R4 transmission from a 1986 Sport Coupe and one from a 1986 IROC(or Z28) ?
I had a person at work tell me if I had an IROC(or Z28) tranny it would have been fine behind my 383 TPI. The reason mine went south was the fact it was a Sport Coupe tranny. The engine was of no concern! Is he right? How can I prove him wrong?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Apr 10, 2001 | 08:27 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
They are the same. Of course there may be small differences in valving between models (some have wot in 4th gear ability, and some have manual tcc lockup valves) but they are the same up to when they upgraded the valvebody (in 87)
The six cylinder transmissions are slightly different (input drum has different dimentions [less frictions]) but even most of these parts are interchangable with v8 parts of the same design.
Basically it breaks down into early models (up to 87 1/2) and the later 30 spline auxillary valvebody models (87 1/2 up). May parts between the two designs are interchangable, some interchangable with slight modifications and others are totally dedicated to that type (reverse input drums, valvebodys, sprags....)
BAMiller
Sep 14, 2015 06:38 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TheTraut88
Sep 7, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
greenyone
Sep 2, 2015 03:39 PM
