no second gear 700r4 help!!!!!!!!!!
Old Apr 9, 2001 | 03:54 PM
Hanks1's Avatar
Just pulled the 305 out of my 84z and dropped a 355- second gear stopped working all the sudden-no slipping no noises??? any ideas. all other gears work fine and the converter locks up-fluid pink smells ok not burned.will go from first to third when in drive unless im gasing it then it drops into first again at high rpms. if i shift into 2 around 20 it is like neutreal then it revs high enough to be in first.PLEASE HELP dont feel like spending more money than the $2500 motor job that f**ked my trans up
84 Z28
355 chevy 9.5-1 about 350 horse. many mods
Old Apr 10, 2001 | 12:36 AM
BryanJ's Avatar
I had the same problem in my trans. for 3rd gear the guy had just rebuilt my transmission so he fixed it for free he said I burnt all of the cluches in 3rd
hope that helps out
Old Apr 10, 2001 | 05:01 AM
Pro Built Automatics's Avatar
Do you still have overdrive? Are the shifts at light throttle openings at the right time?, or are the shifts very late? I need to know this, so I can be of some help!
Old Apr 10, 2001 | 10:40 AM
Hanks1's Avatar
still have od-shifts fine other wise- what i was talking about down shifts i mean when in third if i accelerate,when it should kickk into second it dumps into first. If i manually put it into 2 it is like neutreal until it is in first gear rpm range
<font face="Verdana, Arial" size="2">Originally posted by Pro Built Automatics:
Do you still have overdrive? Are the shifts at light throttle openings at the right time?, or are the shifts very late? I need to know this, so I can be of some help! </font>
Old Apr 10, 2001 | 04:01 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Intermediata clutch/band (not sure on 700r4, I will look it up and repost!) could be burned up. You said the fluid is pink, right?
Old Apr 11, 2001 | 02:20 PM
Hanks1's Avatar
its pink alright and doesnt smell burned either.
<font face="Verdana, Arial" size="2">Originally posted by JAYDUBB:
Intermediata clutch/band (not sure on 700r4, I will look it up and repost!) could be burned up. You said the fluid is pink, right?</font>
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
TheTraut88
Sep 7, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
