ATTN: Pro Built
Old Apr 10, 2001 | 10:55 AM
cbpldc's Avatar
ATTN: Pro Built
I have a 2.8 with a T-5 behind, 1984 to be exact. It makes a grinding or quick vibrating noise in 1-3 gears when I have the clutch out but when I get into 4th gear, it is quiet as any other tranny should be and also when I have the clutch in. Do you have any idea what this could be? Also, when I am idling with the clutch out, it makes a rattling noise quite often, but when I put the clutch back in, it doesn't make the noise. Any ideas? The car has 127k on the stock drivetrain. Also, this may not have anything to do with it, but my starter is going bad and when I try to start it, it will turn over the engine very shortly, then it sounds like it just grinds and then I have to that a few more times to get it to start. I hope this is enough information.
Thanks,
Chris
Old Apr 11, 2001 | 03:40 PM
Pro Built Automatics's Avatar
I have not done a manual in years, but from what you are saying (4th being quiet) it sounds like a bearing is going away. The same things used to occur in Muncies & BW ST-10's.
Hope This Helps!!!
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
Pinguiclia
Oct 12, 2015 04:47 PM
roysatikas
Sep 22, 2015 08:15 PM
89newfun
Sep 16, 2015 09:28 AM
