Tranny Question - 700R4
I have my tranny out and am putting in a new TC (2500 Stall), servo and shift kit (Transgo). Should I put new clutches in it while it is out??? Is there anything I should change?? The trans only has 28,000 miles on it. I want to make sure that I am not having to take it out again next year or the year after.
1989 Pontiac Formula L98 Ported Plenum, Edelbrock 6085 Heads, Edelbrock HI-FLO Intake, BBK 52MM TB, Edelbrock TES, FlowMaster 3" Exhaust, Dual Cats, 3.27 Gear, CompuCam 2032 Cam, 1.5 Rollers, Ed Wright FastChip, Accel Super Coil, MSD 8mm Wires
Do the update on the 3-4 clutch pack, put in the Borg Warner Hi-Energy clutches (8) & Kolenes steels (7). Second install the Viton input/output seal (used in all 1992 & later 700R4/4L60E's) in the input drum. This will guarantee oil to the rear planet. Third put in the new clutch return springs supplied in the Trans-Go Performance Shift kit. Fourth you could install the Turbulator (low Drag) steels in the reverse input drum & in the low/reverse pack. Fifth install the Borg Warner Hi-Energy 2-4 band, along with the Corvette servo, and large boost valves. They should be in the Performance kit that you bought, if not make sure you get them.
Hope This Helps!!!
Hope This Helps!!!
Pro-Built: why I have your attention. How difficult is it to install the servo and boost valve? Never done it before.. What cost am I looking at for the items you mentioned??
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
check this for how to install a servo
http://www.sethirdgen.org/servo.htm
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation/
Thornburg
Aug 25, 2015 01:46 AM
