Shift Kits, Which Should I Get??
Old Apr 10, 2001 | 01:56 PM
twells's Avatar
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
I Have a 92 700-R4 in my camaro and am going to put in a shift kit soon. I have heard roomers that the b&m kits will tear up our transmissions. I would like a trans-go shift kit. Is this a good choice, and how hard will it be to install? Thanks TWells
1992 R.S. 25th Anniversary
* Borla
* Open Element
* Hypertech Chip
* Smog pump delete
Thats all for now!!
Old Apr 10, 2001 | 06:06 PM
BTS88IROC's Avatar
Twells,
I believe the rumors are true about the B&M kits. They are too harsh on some of the components. The Transgo kits are very good kits and will not ruin the tranny. If you get the one from summit it will even come with a video that shows you how to install the whole things so it shouldn't be much of a problem.
Also where in kansas are you located?
We are having a statewide gathering in wichita on the 14-15.
Old Apr 10, 2001 | 08:21 PM
rondubbs's Avatar
just get a vette servo and .500 boost valve, you'll get the same results as a shift kit and it'll only cost you $20...
http://hptransparts.com/
Servo kit & boost sleeve, 700-R4
#HP35952-K servo kit, accumulator piston and boost sleeve (.500") and Corvette style servo
#HP35952-K...$18.19
Old Apr 10, 2001 | 08:48 PM
82camaro's Avatar
Car: 82 camaro SC
What ron said. I did this to a 4.3L V6 tranny and it chirps the tires in my 82.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 10, 2001 | 09:17 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Are u guys now saying that u don't have to get a shift kit if u just get those 2 things?? What if u get those and the shift kit??
Looking For:
87 IROC-Z28 350 TPI
The car I want.
84 TRANS AM 305 H.O.
Another car that would be OK to own while I still look for the IROC-Z!!
Old Apr 11, 2001 | 01:50 AM
BlueZ89's Avatar
How hard is it to install those parts? Do you need to drop the trans or pull the valve body? Does installing that kit do any damage or cause any premature wear to the tranny?
Old Apr 11, 2001 | 06:36 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
For the servo you might need to lower the trans or loosen the x-member and pry it over to the drivers side (Not unbolting for the motor)
The boost valve you don't have to drop the valve body for. It goes in the pump under a snapring.
Old Apr 11, 2001 | 08:46 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I guess your e-mail doesn't seem to work, but I've got a new TransGo shift kit (for 700R4) that's never been opened that I've decided not to install and will sell for $100 shipped (in the US) if you or anyone else is interested...
KAM
Old Apr 11, 2001 | 03:05 PM
Administrator
Are u guys saying that u don't need a shift kit if u just get those 2 things?? What if u get those and the shift kit??
Looking For:
87 IROC-Z28 350 TPI
The car I want.
Old Apr 14, 2001 | 04:13 AM
Administrator
Old Apr 14, 2001 | 05:51 PM
rondubbs's Avatar
<font face="Verdana, Arial" size="2">Originally posted by IROCZTWENTYGR8:
</font>
yup thats what im sayin
some transgo kits come with the vette servo,, itll just make it shift even harder.. id save 100$ and just get these stock gm upgrade parts.. you never know what the shift kit might do to your car and every high performance mechanic i've ever spoke to said NOT to get a shift kit..
sethirdgen.org has a tech article on the vette servo installation..
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
