torque converter
Old Jan 7, 2009 | 09:10 PM
turbo11g's Avatar
torque converter
I see that the converters for the 4 cyl and 6 cyl are smaller than the ones for the v8 with the same trans. Will the smaller one work behind the v8 like a stall converter? We used to use vega converters in our th350 and they stalled around 2300.
Old Jan 8, 2009 | 11:39 PM
Pro Built Automatics's Avatar
Re: torque converter
If the bell housing is different, then the input shaft is different also, and the torque converter to crankshaft hub is too. No, it will not interchange.
Old Jan 9, 2009 | 07:43 AM
Shagwell's Avatar
Car: projects.......
Old school. - You should see what those vega converts do in a th400 behind a bbc. - They really don't like t-brake launches, but work pretty well foot-braking.
The only drop-in v6 tc is the s10 4.3 converter. IIRC, it's known as a B29 and will give you around a 2k-2200 stall.
Although they work fairly well, just as the vega converter, it's not nearly as efficient as a properly built stall converter.
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
