I want to do this swap,
What will I have to do?
I read about the VSS not fitting into the T5 what can I do to make it work?
Anyone ever done such a thing on here?
or to any vehicle originaly equipped with a 700-R4
driver101
close
what year is the wagon and what year is the tranny 90-92 camarp had a electric vss and t/a had it back in 87
its a 92 wagon with a Gen1 358 motor, Havent got a trans yet, Gauging the amount of money an effort.
Family freind has done a swap into a ford truck of his I was going to ask him to help me do the swap.
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:26 Times in 22 Posts
A 700R4 VSS will not work with a T5, nor vice versa. But you can swap a T5 cable VSS with a T5 electronic VSS with no problems.
There is a tech article on this site about swapping a 700R4 for a T5 or a T56, but its for a thirdgen. Perhaps there's a Caprice forum that will be more help? Or the Impala SS forum? I know those guys have swapped T56's into their cars and the 91-96 Caprice and Impala are the same style body.
Im on www.Impalassforum.com that swap hasnt been done realy, just talk of it, Most use T56s because they can witstand more than a T5.Originally Posted by Kevin91Z
A 700R4 VSS will not work with a T5, nor vice versa. But you can swap a T5 cable VSS with a T5 electronic VSS with no problems.There is a tech article on this site about swapping a 700R4 for a T5 or a T56, but its for a thirdgen. Perhaps there's a Caprice forum that will be more help? Or the Impala SS forum? I know those guys have swapped T56's into their cars and the 91-96 Caprice and Impala are the same style body.
a Guy said that I would prolly be spending just as much money to keep it alive, vs getting a T56
what a downerSupreme Member
He's probably giving you pretty sound advice there. A Caprice wagon is a fairly heavy vehicle, and the T5's have enough trouble surviving with just the weight of a 3rd gen f-body. In fact, that's why they usually last longer in the fox body Mustangs versus our cars due to the lighter weight of the stangs. A T56 would live a long, healthy life in your wagon, or a Tremec TKO for that matter.
