What 700-R4 do i have ??
Old Apr 16, 2001 | 02:57 PM
jim86's Avatar
I just pulled the trans out of my '86 Z28. I had heard that there were some improvements in '87 so i assumed since i had an '86 mine wouldn't. But i looked in the FAQ's the other day and it said if the casting number ended with '732' then you had the trans with the improvements. I looked at my casting number and it is 8654732. Does my trans have these improvements ? The car had 130K on it so i guess it's possible another trans was put in before as i just recently purchased it (last year). Can anyone tell me for sure what this casting number corresponds to as far as year and whether or not it has the upgrades made around '87. The car was built in late '85, so it's not like it's a late '86 thing. Thanks for any info
Old Apr 16, 2001 | 05:51 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
You could pull the pan and check for sure, since changing the filter would be a good idea anyway. If it really is an 86 it probably (most likely) is the older version although maybe it was swapped before.
Old Apr 16, 2001 | 07:56 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
look for a seem just above the trans lines it will be very long and arched. if you do than you have the better one.
Brendan
Feb 20, 2003 02:14 PM
mystikkal_69
Car Audio
Dec 8, 2001 07:20 PM
FIRECHICKEN
Dec 4, 2001 08:56 PM
ADMZ24
Aftermarket Product Review
Apr 26, 2001 02:40 PM
kidpunkr
Jul 28, 2000 07:52 AM
