Will Trans-go 700r4 kit help with the downshift too?
Old Apr 16, 2001 | 07:13 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I think I'm going to go ahead and get the kit but I wanted to know if the kit helped with that down shift prob as well??
Cause I see that kit by B&M for that, but I don't want to get B&M
Just courious
THANKS
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
[This message has been edited by Hecubus (edited April 16, 2001).]
Old Apr 17, 2001 | 11:45 AM
Pro Built Automatics's Avatar
Are you wanting to eliminate 4-3 kick down? If this is what you want, you can do the work yourself by blocking the part throttle kickdown passages in the TV bushing. Use two Allen screws for this, then grind flush so as to not to interfere with the bore or valve. If you have questions on this call me 800 7763288 Mon-Sat 10-6 PST.
Hope This Helps!!!
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
