Muncie m21 into a 91 700r4 car...need quick answer before it sells!!!
Old Apr 15, 2001 | 12:48 PM
Josh 91RS's Avatar
Hey one of my good freinds dads just pulled the hopped up m21 he had in his 67 camaro with over 550 horses....hes selling it for $400, but i have to let him know really quick whether or not i want it...How easily will this go into my 91 which has a 700r4 in it now? How much fabrication will i have to do? Can i just get pedals,clutch, all that good stuff off of a t-5 car and use those? Would this swap be worth it? Its either that or i spend money on a torque converter now, and then switch in a new 700r4 which even from the tranny doctor will cost me $1,000. What will it take to get my speedo to work? Any other problems? I am currently putting in a new 355...carb, no computer...so that isnt an issue.Thanks for any help!!!
Old Apr 15, 2001 | 12:55 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
https://www.thirdgen.org/messgboard/...ML/002265.html
Go to the link up top and see why you shouldn't do it. I've done it, and it ain't pretty.
Spend your money on a Yank, Vigilante, or Pro-Torque convertor, and your car will feel just like a stick.
Old Apr 15, 2001 | 12:57 PM
Josh 91RS's Avatar
Well the only thing is this...my tranny has like 200,000 miles on it and im throwing a 450 horsepower 355 in it right now...so i know its not gonna last at all...since im gonna have to replace the tranny anyhow would it still not be worth it??
Old Apr 15, 2001 | 01:12 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
You will have to fabricate a crossmember to hold the torque arm, cut the floor longer to fit the shifter, and get your driveshaft lengthened. The shifter linkage was a pain in the *** , and the shifter handles were too.
It's up to you, like I told the other guy, but I've been there and done that, and I wouldn't do it again. I would have been better off putting in a T-5 or Tremec, and I started with a manual T-5 tranny in the first place.
There is a lot of fabrication involved, and it will cost you some ca$h if you can't do it yourself.
Just my $.02, but you'd be better off with getting your 700R4 built and getting one of the top converters.
Old Apr 15, 2001 | 01:13 PM
ede's Avatar
ede
you could do it, but you could do about anything if you have the time and money for it. spend your money on a t5 or tremac if you want a manual or get the 700r4 rebuilt if there is a problem with it and up grade at the same time.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 15, 2001 | 01:19 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Since you are in CA, take your tranny to Pro-Built, I've got one, and I beat the crap out of it. I don't know if the tranny doctor is any good, but always get references from people who are running the tranny you are thinking about buying.
I was just over a friend's house yesterday helping him rebuild his 700R4 that was suposedly 'built' by some shop in CA only a year ago. It lost 2nd and 4th gears after we put a shift kit in it. After taking it apart, the pump is shot, and many other parts are damaged.
Everybody can't build 700R4's, go to Pro-Built and get it done right the first time.
Old Apr 15, 2001 | 01:25 PM
Josh 91RS's Avatar
Well guys thanks for the replys....although i think it would be cool to have something in it not many people have, ive had enough fabrication with this engine for a while...so i guess ill just stick with the 700r4...either get it rebuilt or buy a new one. I just hope it last at least a little while...That or i might just pull it out now since the engine is out.
Old Apr 18, 2001 | 02:26 AM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
those cars with the muncie were great cars,,in there day ,,the m21 the super t10,the saginaw ,,heavy clutches,scatershields,,,,Neanderthole,,,i would go for a simple t5 borg warner, like a one piece bellhousing model ,,,there must be thousands in america, in junk cars,, they are nice to drive, good ratio,s soft clutch ,easy to fix,,dont wine,dont feel like a kenworth truck,dont get a soor back ,from the clutch pedal ,dont crunch in reverse,if the engine is idling a bit high,, i live in australia things are big$$ here ,,,we used the T5 in 300hp production cars here they were in the G.M cars made here, you can drive hard without blowing the side out of it, or stripping gears,,good luck will take honest HP,, GERTRAG is better 6 spd or hollINGER 6 SPEED no clutch ALL AUSSIE MADE WILL TAKE 700HP all dav
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Sep 17, 2015 12:22 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
mcgarnicle
Aug 12, 2015 04:58 PM
