26 to 28 spline axle swap
I've been thinking about going for the OEM zexel torsen takeoff, but it won't work with my 26 spline axles. New axles cost too much for me at this point, so I'd like to check out some junkyards to find a set of 28 spline axleshafts. Is this a stupid idea? I don't know what kind of wear axleshafts get over time, or if there are any other things I should be concerned about. Basically wondering if I should go junkyarding or not take the chance.
Transmission: 4L80E/4L80E
You could probably get an entire used rear for less than one new 28 spline axle. You could have the Zexel put in it while you continue to drive your car (assuming you aren't set on using your current gear set).
The main problems I've heard of with axles is being bent by sliding sideways into curbs. Next after that is abuse from popping the clutch in manual cars - the axles typically snap, rather than being weakened and then breaking.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
Car: '85 IROC
I called all the junk yards withing driving distance from me and nobody could come up with the 28 spline axles. I finally got a pair from Camaro Heaven (1-800-CAMARO1). He only had one for disk brakes, so I had to turn down the flange on the other one to fit.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The only cars that have the 28 spline axles that you can use are 90-92 models. 93 and up are 2 inches longer. Good luck finding 90-92 models in the junkyard and if you do they probably want too much for the axles anyway.
You can get 28 spline aftermarket axles from www.tomsdifferentials.com for $125 each. Part number is KAC7-A7. They're a direct fit in 82-92 f-bodys with a 28 spline carrier and drum or disk brakes.
** URL edited **
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited April 18, 2001).]
** URL edited **
Best 60 foot: 1.662
I tried the link for the direct fit 28 spline axles and it did not work. Do you have another contact so I can get these axles? Seems that hardly no one wants to beef up a 7.5. I am thinking of 28 spline aftermarket axles, mini spool, and girdle/cover for my 7.5. I think this should hold for some good horsepower. The drop in 9-inch thing I think is a little pricey. What does anyone think?
<font face="Verdana, Arial" size="2">Originally posted by Tadder:
I tried the link for the direct fit 28 spline axles and it did not work. Do you have another contact so I can get these axles? Seems that hardly no one wants to beef up a 7.5. I am thinking of 28 spline aftermarket axles, mini spool, and girdle/cover for my 7.5. I think this should hold for some good horsepower. The drop in 9-inch thing I think is a little pricey. What does anyone think?</font>
Try http://www.tomsdifferentials.com/ for Tom's Differentials. Have you considered the Dana 44? SLP has a few left. They're pricey, but stout.
Happy Motoring,
Harry
Genopsyde
Oct 7, 2015 08:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
