***ATTENTION TKO AND T56 USERS!!!***
Old Apr 17, 2001 | 12:14 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
I've been searching this board for articles concerning the TKO and the T56 and I havent found the answers to my questions, so hear we go!
1- Which is stronger?
2- I read a post stating that the TKO's 1-2 gear spread will cause a severe rpm drop (post stated 6500 to 3900). Is this true?
3- Will the aftermarket T56 stand up to hard launches and power-shifting?
4- To those who have both, which one shifts better?
Thanks for all the help in advance.
Old Apr 17, 2001 | 09:07 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
ANYBODY?
Old Apr 17, 2001 | 09:57 AM
Chuck Everly's Avatar
I had the Tremec 3550 (I think that was the number) and I do not recall a large drop in RPMs like you mentioned. I was told the only difference between the 3550 and the TKO was the output shaft.
I did not care a lot for the Tremec transmission. It has a very notchy shift in my opinion. It was durable but if I were to do it over I would think seriously about a T56 swap. I think a T56 with 4.10 gear would make a nice combination.
I think both will stand a lot of abuse if you are not putting over 450hp to the ground.
Old Apr 17, 2001 | 01:44 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Thanks Chuck for the info...
Anyone else?
Old Apr 17, 2001 | 03:54 PM
iroc22's Avatar
I thought that the 3550 and the TKO were the same tranny except that the TKO was beefed up a little bit. The TKO is supposed to handle 525 ft/lbs of torque and well over 600 horsepower. Don't know too much about the T56
check out my website
http://members.v3space.com/thirdgen/index.htm
Old Apr 18, 2001 | 01:06 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
there are a couple different geard ratio options in the t-56. one from 93 that handles 400 lbs torque and then the 94 and new with a higher gear that handles 450lbs. I think it comes in to what tires you will be running a bit hear. I am pretty sure a t-56 would handle 500 +lbs if you are running 275 normal street tire. you would just spin the tires. I have one for my chevelle and I am going to put a 502 in it and I don't think it will be a problem.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
1MeanZ
Dec 18, 2015 05:39 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
tonys91rs
Sep 2, 2015 07:07 PM
