REAR END
Old Apr 18, 2001 | 09:39 PM
BORLAZ06's Avatar
REAR END
I HAVE A 92 CAMARO Z28 AND I WAS WONDERING WHAT REAR END SHOULD I GO WITH, 12 BOLT OR A FORD 9 INCH. WHICH IS BETTER? THANX
92 CAMARO Z28
BLACK ON GREY LEATHER
305/ 5 SPD
[This message has been edited by BORLAZ06 (edited April 19, 2001).]
Old Apr 18, 2001 | 10:49 PM
RARE-ROC-Z's Avatar
well since you didnt give me any info on the car. i would say that 9", they rarely ever break. its almost impossible especially for an Fbody.
but either one will work.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Apr 18, 2001 | 11:45 PM
enigma57's Avatar
<font face="Verdana, Arial" size="2">Originally posted by BORLAZ06:
WHAT REAR END SHOULD I GO WITH, 7.5 OR FORD 9 INCH. WHICH IS BETTER? </font>
Hi, BORLAZ06!
Jarrad's right! 9" is MUCH stronger rear - If you plan on 300 HP or more, don't waste time and money on 7.5" 10-bolt.
Happy Motoring,
Harry
Old Apr 19, 2001 | 12:02 AM
KW87GTA's Avatar
I would go with the 9 inch in you plan on building up your car or if it is already built up, I have one from Moser myself. However, they do offer another alternative as well, and that is the GM 12 bolt. I don't know a ton about 12 bolt's but I am sure that it is also very strong. It is just a touch cheaper from them too. The whole thing from Moser seems to be a really good deal now too, it bolted up fairly easily for me and almost everything stayed perfectly in place. You can buy it direct or I believe SPOHN carries it as well. I had just two problems which I will tell you, but I am not sure if Moser has addressed them yet. Firstly, you will need an adapter to keep your rear sway bar. SPOHN sells this I think for like $70, then there was two pieces of maching that I had to do. Firstly, Moser didn't offer the complete unit like they did now, so I put on a Strange case. The torque arm bracket that bolts too it needed to be machined to clear touching the case, and I could not use the long pass through bolt on one side of it. I haven't had any trouble with it since though. The other thing was there is a plate that needs to be machined to go over the axle on the wheel hub near the brakes. This cost me $150 to have machined properly. Other than that, the 9 inch is supposed to be the strongest rear around. I put a locker in mine, which is not as pleasant as a slip but much better hook up. Good luck.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed TB coolant, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
