where could i get a limited slip Differential
Hi i got a 88 camaro, with the 2.8l v6, and was wondering where i could find a limited slip differential that would fit in my application and if i had to change anything?
Re: where could i get a limited slip Differential
You need to know what the gear ratio is. If you have a 3.08 or 2.73 you will need a 2 series. If you have a 3.23, 3.42 or 3.73 you will need a 3 series. You will need one for 26 spline axles. Do you want an Eaton or a Truetrac? If you can't find anything let me know. I can get you a new one. You will need bearings and shims to go with it.
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
http://www.ringpinion.com/PartCats.a...fName=GM%207.5
They have a nice selection of things for the 10 bolt, summit sells them also. Although, its usually cheaper and more time efficent to go to a Junkyard and find a whole posi rear and just swap that in.
