700r4 No gears engage Help!
Old Jan 12, 2009 | 06:41 AM
83Z28SBC's Avatar
Car: 83 Camaro Z28
Engine: 355 Vortec Intake/Heads
Transmission: 700R4 Shift Kit 2500 stall
Axle/Gears: Stock
Any input would be helpful.
I just did a 305-350 engine swap. Also put in a rebuilt 700r4 and 2500 stall. I seated the stall, spun and seated a couple of times. When I spun it it sounded like gravel but spun freely, not sure if this was good. I put 1 quart of tranny fluid in converter and 4 in the tranny before putting in gear. Jacked rear end off ground and put in gear. Added 6 more quarts, (total of 11) to the tranny but the wheels never engaged in any gear. While car was in gear I disconnected the tranny lines at the radiator to make sure fluid was pumping and made a huge mess. Plenty of fluid shooting everwhere. I ran hose from the input/output to make sure there was no obstruction in the radiator/external cooler that was causing an issue. So that is where I am, fluid pumping fine but no gears work.
Old Jan 12, 2009 | 04:05 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: 700r4 No gears engage Help!
did you rebuild the transmission yourself
cause from my experiance the smallest thing in an auto can make a big difference. if you took it somewhere id take it back and have them take a look at it
Old Jan 12, 2009 | 04:54 PM
83Z28SBC's Avatar
Car: 83 Camaro Z28
Axle/Gears: Stock
I did not rebuild it myself, the guy I got if from had it done 2 or more years ago and it just sat. The pump seals and pan seals where new, but I know nothing about what was done inside other than shift kit.
Old Jan 12, 2009 | 05:00 PM
90c350's Avatar
Did you put the car on the ground and bring the rpm up?? Could just be the converter not engaging? Just a thought
Old Jan 12, 2009 | 05:05 PM
83Z28SBC's Avatar
Car: 83 Camaro Z28
Axle/Gears: Stock
I did not have it on the ground, just on stands. I did rev to around 3k just to make sure I was hitting the stall range. I have a sneaky feeling that the converter was a 30 spline instead of the 27 but I will have that verified tomorrow. I called Decco, the converter maker and thier tech told me that the 30 spline would go on a 27 spline shaft so I hope that it is that simple.
One thought, is it possible to mount a 30 spline converter on a 27 spline shaft? anyone have experience with this?
Old Jan 12, 2009 | 06:32 PM
83Z28SBC's Avatar
Car: 83 Camaro Z28
Axle/Gears: Stock
Case Solved!! It was in fact a 30 spline converter!!!!!!! Just need to make sure I did not grind the splines of the shaft, then I am good to go.
Old Jan 13, 2009 | 01:08 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
you could check in the pan and see if the trans has a thirty spline or 27.
look for a pipe going from the pump to a housing located behind the valve body called the forward accumulator. if it has the pipe the trans is probably a 30 spline and that is not your problem because it would ba a 86/half up core and uses a 30 spline. The builder might have forgot to hook up the manual valve inside the pan also-check your linkage internally(I've done this myself but won't admit to it-doh!)
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
