Dakota Speedo Interfeace is great!
Old Apr 19, 2001 | 03:53 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Got it hooked up in my GTA with the T56 and it works great!! I recommend it. Only thing is that I had to use a different output # than the one they said to use on TPI cars. Works great though
'91 GTA:
www.fbody.com/members/91WS6GTA
Old Apr 20, 2001 | 08:43 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I hooked mine up last weekend and mine also works great. A lot better than that Cyberdyne POS. Anyway, I also had to use a different output. I think it was the #3 output. Good luck and have fun.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Apr 20, 2001 | 11:33 AM
Mark W. Winning's Avatar
How did you connect it? I was looking at their instructions last night. Did you totally bypass the ecm or did you just install it in the VSS (2) wires going to the ecm.
Thanks...
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Eric2ndGen
Nov 5, 2015 01:51 PM
camaroinmotion
Exterior Parts for Sale
Sep 2, 2015 08:25 AM
THEBEAST84
Classified Ads Feedback Board
Aug 31, 2015 06:55 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
