How many tenths can I expect to gain?
Old Apr 16, 2001 | 07:15 PM
MikeC.86Roc's Avatar
I am currently running a W.C. T-5 with ltd. slip 3.08 rear in my 88 Iroc. My 60 foot times are horrible and 1/4 is not where I think it can be with my motor's potential. Anybody think I could technically get it into the high 12's with a 3.73 rear or 4.10? Slicks would be in order too I know. I am aware of the T-5's breaking point but I don't care, I am gonna rag it out till its toast. I am thinking about getting a Moser 12 bolt rear with 3.73s and eventually hook it to a T-56. Thanks!
Mike C
88 Iroc 5spd
355 TPI, AFR 190s and lotsa other mods
86 Iroc in pieces!
Old Apr 16, 2001 | 07:59 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
What did you do for mods? your hp?
Old Apr 17, 2001 | 09:28 PM
O.k., I didn't wanna do the mod list unless it was needed so here goes.. AFR 190's milled to 58cc static 11:1 comp. Custom EFI roller cam 218in. 228ex. @.50 lift. Roller rockers, 1 5/8 headers, random tech catback and no cat, 24 lb. injectors with edel base, stock plenum and runners and 48mm body with damn MAF (i know i know this setup is a bottleneck)... Thats the guts of it, no ignition upgrades at the moment...
Old Apr 17, 2001 | 10:17 PM
CamaroX84's Avatar
What are your current 60 ft. and 1/4 mile times?
Old Apr 20, 2001 | 08:09 AM
I can't believe I forgot to post those... DUH! My 60 foots are like 2.3's and 2.1 is best so far! My best quarter time is 13.46 @ 104. Thanks!
Old Apr 20, 2001 | 11:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
3.73s, a good torque arm and LCAs, LCA relocation brackets, and good tires ought to get you 60' times down into the 1.8x range, at least once or twice before the trans spills its guts.
ICON Motorsports
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
hartsmike
Oct 2, 2015 07:11 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
