makin posi from a 1 legger.
Old Apr 19, 2001 | 11:44 PM
Slow83Z28Camaro's Avatar
ok i soposly read and heard bout this, is it true that when u take out the pin in the rear u have instant posi? if so has n e 1 tried this and is there n e bad things bout it?
80 series flowmaster,8.8, 2.5 in exuast plug wires, accel super coil,accel distriburator, 650 holly n a polished elderbrock rpm performer comin soon
Old Apr 20, 2001 | 05:55 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I garuntee that if you try that, you will never do it again.
First of all, that "myth" is false. There is alot more to making a "limited slip" than just removing a part. It helps to know how one works.
Second, that pins purpose is to keep the axles pushed outward, so the C-clips don't become unseated. Its the C-clips that keep the axles in the rearend. Have a C-clip come out while driving, and you will cry "uncle".
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 20, 2001 | 12:10 PM
thanx for the info
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
