rear end
Old Apr 18, 2001 | 07:41 PM
rita's Avatar
rear end
I have a 84 z-28. I would like to know if anybody could help me find out what axle ratio and what axle type I have. Here is the axle code that I find on the axle housing. 6hs c167 1.
Old Apr 18, 2001 | 09:28 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
my book doesn't show that number.you may want to look again
Old Apr 19, 2001 | 06:38 PM
rita's Avatar
I will look at it again this weekend.
Old Apr 19, 2001 | 09:13 PM
rita's Avatar
I went out and looked today. The only numbers I seen is 6HS C187 1 OR 6H8, 6H5.Would it help if I gave you guys the vin #. I have that haynes automotive repair manual for 1982 thru 1992 camaro. but I couldn't find it in that book.
Old Apr 19, 2001 | 09:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1984 f-body axle code 6HS = 3.73 Locking
There is no 6H8 or 6H5
I don't know if the "locking" is a posi or a gov-lock.
C = Buffalo assembly plant
167 = day or year
1 = day shift
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited April 19, 2001).]
Old Apr 19, 2001 | 10:00 PM
rita's Avatar
what is the difference between the poi or gov lock . What is a gov lock.
Old Apr 19, 2001 | 10:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
A gov-lock is normally an open diff but when one wheel starts to spin, the diff will lock up. When you see one you'll know what it is. It doesn't look like a posi with clutches or cones.
It will unlock again when the wheel speeds are different such as going around a corner. The locking mechanism isn't that strong for performance applications but it still works. My truck has one and I've never had any problems with it.
Old Apr 20, 2001 | 06:00 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
One easy way to find out your gear ratio, is to drive your car at 70MPH w/ your tranny in the 1:1 ratio (3rd for a 700, 4th for a T-5) and whatever your RPMs are, reflect your ratio. For example, my car w/ 3.73s cruise at 3700 RPMs, a 3.42 will be 3400, 3.08 will be 3000, etc.. I think you can make the connection.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 20, 2001 | 12:11 PM
rita's Avatar
I will try that but I will have to find a steel or aluminum driveshaft hopefully an aluminum. If any can help me find one in canada or close dy please let me know
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
