Optimal sensor placement.
Old Apr 16, 2001 | 08:19 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Where would be the best place to put an aftermarket guage sensor. I would like to put it in a place that gets the hottest. Preferably somewhere that is already tapped to accept a fitting. I have a 700-R4.
89 TRANSORMULA WS6 5.7
Dark Purple Hardtop!
Ram Air II Hood
Z28 Hi-Rise Spoiler
HYPERTECH THERMO MASTER
10-BOLT POSI, 3.23 GEARS
MODIFIED TRANSMISSION
K&N FILTER CHARGER
MODIFIED MASS AIR SENSOR
PORTED & POLISHED INTAKE
ACCEL COIL & 8.8 WIRES
EMISSIONS DELETE
DYNOMAX EXHAUST W\ TIPS
CUSTOM SOUND SYSTEM
BEST TIME 14.32 @98.3 mph
Power buldge hood
^^ FOR SALE ^^
[This message has been edited by FIRECHICKEN (edited April 16, 2001).]
Old Apr 17, 2001 | 09:10 AM
scauffiel's Avatar
You mean in your tranny? I'm putting one in the pan. Going to either get an adapter for the drain plug hole or drill and tap for a separate hole expressly for the sensor. I'm putting mine in the pan because that's the temp of the fluid when it's picked up by the tranny.
Steve
Steve's Trans Am Temple
Old Apr 17, 2001 | 03:00 PM
Synergy's Avatar
I bought an autometer guage and a chrome tdi products pan. Drilled a 1/2 hole in the side of the pan and the sender screwed right in. Make sure to use some liquid teflon around the hole to make sure it doesnt leak.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Apr 22, 2001 | 01:48 AM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
I always thought it was best to run it into the cooler line going to the radiator. With a t fitting or somthing. Is the pan a better place?
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
