Noob question about turbo 350 trans. :s
Car: 1991 Z28
Transmission: 4l60e
Aight so ive been needing a tranny for a while, just something cheap. I found a turbo 350 tranny that comes with torque converter. Now i'm not to keen on transmissions, so for the sake of putting my parania to rest, the turbo 350 will bolt up to my 350 tpi? I wouldn't wanna buy the wrong part after all.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Noob question about turbo 350 trans. :s
Although it will fit, it's not a direct replacement into a third gen. You'll need a conversion kit or will need to do some modifications.
The transmission crossmember isn't in the correct position. A conversion kit has an adapter to reach the tranny mount which will be about 2" forward from where the 700R4 mount is.
Third gens have a torque arm suspension. The front of the torque arm is mounted off the back of the transmission. A conversion kit provides a new mount bracket to install the torque arm on the transmission.
A simpler way to do the swap is to install an aftermarket torque arm with the proper tranny crossmember. The aftermarket torque arm moves the front mount off the transmission and onto the crossmember.
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
moonlight-the profile says 4l60e-what gives. at most the trans is a 4l60. The th350 you want is the long one. it measures 9" housing on the back of the TH350 so that it will be the same length as the 700r4-4l60 it is replacing. It is called a long th350 with the 9 inch housing. THe driveline will fit this one also.
84z96L31vortec
Aug 20, 2017 12:16 AM
