Is this normal???
Old Apr 28, 2001 | 12:26 AM
RyanSS's Avatar
Is this normal???
I have an 89 RS(in sig) (just recently got it running) and when it's at WOT it's shifts are very hard(like jerk you back in the seat)feels like it's gonna break something
Is this normal?
If not, what is the problem and how do i fix it?
89 RS (supposed 350) TBI auto
Old Apr 28, 2001 | 01:26 AM
transfixleo's Avatar
Some will do this, often on the 1-2 shift. Is it good for it? Well, the Sun Shell likes to break on even stock type units, giving you 1st and 3rd and no reverse so you decide.
You want to have short duration shifts under heavy throttle to minimize the slip and heat build up. How 'hard' that is depends on many factors, including rear end ratio, stall speed, traction and power, along with the calibration of the transmission. If the tires do spin it must be from power overcoming traction and not from a bang shift. You may have something like a B&M shift improver kit, which functions much like popping the clutch on a standard. Also, using the Vette servo and oversized boost valves can have this affect too.I would recomend installing a TransGo Shift Kit or Reprogramming Kit. The Shift Kit will have to be done professionally. If you do the Repro Kit be conservative on hole sizes. If you do this, I wouldn't automatically instal the Corvette type servo (you may already have it) since it will tend to make the 1-2 and 2-3 shifts 'firmer' and that doesn't seem to be a problem for you.
[This message has been edited by transfixleo (edited April 28, 2001).]
Old Apr 28, 2001 | 10:26 PM
mikeage2's Avatar
i had a 84 camaro h.o....every 1-2 shift was extremely hard.i really liked it that way,and actually its better on the clutches that way.some shift kits are made to make the trans shift like that.(i got tickets b/c id be in front of cops,and shifting into 2 would bark the tires)..i took the valve body off,and found the 1-2 accumulator or cushion spring to be broken into 4 pieces.
86 camaro:was a v6 car,now its going to be a v-8 5.7l!!
350:cylinders bored .040 over.a little over 9:1 compression(getting a blower some day when im rich lol)line bored.deck is milled a little(was pitted)
trw forged pistons with summit stage 2 polished rods with arp bolts.
194? intake valves(not 2.02( ),pocket ported,gasket matched,and polished ports,torker2 intake with new zinc 650 holley
matched comp cam...runs great on pump gas!!
ase certified for a few years,learned alot though
working on freakin NEONS ,cirruses,tauruses,cobras(well` at least they look nice lol)and intrepids all day makes me drink too much
good job security though
im always on the lookout for cheapv-8 t-5,s
and t-56 setups.they must be cheap.i dont care of they need rebuild,as long as they arent totally blown
also looking for a pair of iroc taillights,and a 145 speedo(cable driven)
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
