9 Bolt with 3.42 posi gear speed vs. rpm question
Old Jan 26, 2009 | 05:45 PM
old Phart's Avatar
Car: 1989 IROC
Engine: L98 350
Axle/Gears: 3.45 posi 1LE
I am driving on the freeway at 70 m.p.h. and the tach shows 2,300 r.p.m.
Please help me determine what the ratio is on my new gear. Seems like a
3.08 or maybe a 3.27 gear ratio?
Thanks for your help!
Old Jan 26, 2009 | 06:19 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: 9 Bolt with 3.42 posi gear speed vs. rpm question
Im confused as to the title of your thread but ill try to answer the question. I have 3.27s and my rpms are around there or a bit more so the only true way to tell is get under it and spin the wheels. Best way i found is have a buddy spin one of the wheels one revolution. Just a hair more than 3 turns of the pinion is a 3.08, a quarter more is 3.27. Also there is no such thing as a 3.42 9 bolt. It is a 3.45. Im not sure any of that really helped you but if you have a 9 bolt then yes you are correct in your guess. It is either one of those two.
Old Jan 26, 2009 | 06:37 PM
old Phart's Avatar
Car: 1989 IROC
Engine: L98 350
You are correct, it is supposed to be a 3.45 gear ratio. Sorry.
I'll try what you suggested. Thanks.
Old Jan 26, 2009 | 06:48 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Look at the size of your tire. It will probably be a 245/50/16. If you want to be really precise, go to www.summitracing.com, type in the make and model of the tire, and get the specs. Each manufacturer's tire is slightly vaired in height.
Go to this site;
http://www.car-videos.net/tools/speedrpm.asp
Type in all of youre info.
3.06, 1.63, 1.00 .70 for 1st, 2nd, 3rd, 4th repectively, and see what the Speed vs. RPM says on the chart.
You'll have to guess what the rear end ratio is. Try 3.08, 3.27, 3.45. If those dont work, there are a few others you can try for a 9 bolt.
Next time youre on the freeway, cruise along in 4th, and make sure the torque converter has locked up. Just notice what the RPM's are and see if they match your calculations.
According to my calculations, asuuming your TC has locked, and you run a 245/50/16s on the rear;
3.08 = 2050rpm
3.27 = 2180rpm
3.45 = 2300rpm = 70.1mph
You most likely have a 3.45 rear gear.
Old Jan 27, 2009 | 04:04 PM
old Phart's Avatar
Car: 1989 IROC
Engine: L98 350
online170----Thanks for making it easy for me. Looks like you're right. I feel better now. Look for my other post on Vendors.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
