T56 Reverse Pop.
Old Apr 30, 2001 | 11:30 AM
MediaPirate's Avatar
T56 Reverse Pop.
I'm about to purchase a Camaro which was upgraded with a T56. In my test drive the car shifted smooth through the gears, but when I tried to shift into reverse it would pop out. I was warned of this before hand, and was told it was prob. because of a bent shift fork. If anyone else has experienced this or might have another reason and could give me an idea of how much it would cost to get fixed (major or minor repair) I'd appreceate it.
Old Apr 30, 2001 | 11:36 AM
ScreaminDeamin85Z's Avatar
my friend with a 93 Z has this same problem, some times it does it and soem times it doesnt. he has taken it to 3 diff trans shops and they couldnt find the prblem, but other than that they said it was fine.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old May 2, 2001 | 11:58 AM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
Make sure the reverse lockout is hooked up.
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
t-56 trans
9" ME rearend
Old May 3, 2001 | 01:15 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I had the same problem with my T56. The reverse slider gear assemby is bad. It has the synchros and blocker rings in it. The assembly gets chewed up and will cause it to pop out of reverse. This is usually caused from putting the car into reverse instead of fifth because the reverse lockout wasn't hooked up. I got my trans fixed for $150.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
