help with trans ID
Old Feb 3, 2009 | 10:46 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
help with trans ID
Hi boards, i have a turbo 350 with these casting numbers:
GM27 6260933
can anyone tell me about it? or where to look up the casting number?
Old Feb 3, 2009 | 11:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: help with trans ID
It's a TH350. What more do you need to know. There's very little difference between all the TH350 produced. There's an odd chance it's a TH375 but very unlikely.
Casting numbers on anything tell very little.
Old Feb 3, 2009 | 11:33 PM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
a good way to get an idea if the th350 is from a v8 car is to pull the pan and look at the intermediate clutches. you can see them and if there are 2 it probably came from a v6, if there are three it's probably from a v8. the intermediate clutches are 2nd gear clutches. if there are three there will be more clutches in the forward clutch pack also 5 versus 4or3, low reverse 5v.s.4, and direct(3rd)four-which can be upgraded to five with a different piston. Note:if it is a six cylinder th350 that isn't always bad because it has a low planet with deeper gears, and the clutch packs are all upgradeable to more friction material. a pan drop on this unit goes a long way. note: the th350 case is suspect internally as the low roller support wears it the aluminum out. There is a cool upgrade that should be installed in all performance th350's IMO. it uses a bolt in center support that grabs a second set of lugs in the case and a wide 700r4 roller. I don't understand why it is the most overlooked part of th350 rebuilds, as any good shift kit beats the *ell out of this spot. I added a pic.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
