Will not always go into Park
Old May 9, 2001 | 06:57 PM
86blkIrocz's Avatar
And sometimes when in Reverse it will knock but if play with the shifter it will be fine. But the problem with Park is that when it is warm out it will not always go into part. So I have to push the shift lever really really hard to get it to lock into park. How do I fix this problem it is starting to really make me mad.
David Higgins
1986 Black Iroc-Z
305 TPI
Edelbrock Cat-Back
K&N Air Filters
Old May 10, 2001 | 08:28 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
It could be a bad or binding cable or the pawl is worn and isn't engaging the output carriers teeth corectly. If you drop the pan and look up in there, in park the linkage 'bells' out pressing a pawl into the cutouts. Maybe finding a way to tighten this up will cure the problem.
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
lewandom
Oct 1, 2015 08:15 AM
