t5 Question
Old Feb 6, 2009 | 07:28 PM
Jairo's Avatar
t5 Question
My tranny has been acting up lately and my cousin gave me his t5 from his 94 v6 camaro.
i want to know if it bolts right on or does it even fit at all.
i have a 1986 trans am 5.0 t5
Old Feb 6, 2009 | 07:44 PM
Mr355's Avatar
Car: 88 IROC-z "Deathtrap"
Engine: 355 SBC
Transmission: T-5 stage2 Clutch
Axle/Gears: 3.08 Std (Taking a hike)
Re: t5 Question
Should be about the same.. I know for sure the iroc v6 and v8 fit the t-5.. not positive about the fourth gens but i would be suprised if it changed. Also dont know much about the pontiacs but I've heard they are nearly identical. If your t-5 is jacked and needs replacing anyways, and you have the other one... it wouldnt hurt to remove the old t-5 and set both trannys side by side and do some measuring. Good luck
Old Feb 6, 2009 | 08:00 PM
big gear head's Avatar
Re: t5 Question
The '94 will have the Mustang bolt pattern on the case. It won't bolt to your bellhousing.
Old Feb 6, 2009 | 10:16 PM
auto-x1990RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Axle/Gears: 3.23 open diff
Re: t5 Question
you already have a t5 correct?? well iirc, you should be able to pull the bell housing off your old T5 and install it on the new T5 (just make sure to take off the bell housing on the new T5 too)
oh and big gear head, where did you get Mustang out of any of this??? the trans is coming off of a 3.4 v6. definitely not a Mustang trans.
Old Feb 7, 2009 | 06:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: t5 Question
Read the sticky, post #40-41:
https://www.thirdgen.org/forums/tran...ything-we.html
JamesC
Old Feb 7, 2009 | 06:47 AM
Re: t5 Question
I'm told that the 4th gen V6 T-5 transmissions used the Mustang case. I could be wrong, but I got the information from this board. Look around and you will probably find it. I left one on the ground when I bought my '94 3.4 to put in my S10. I wish I had took the transmission too.
Old Feb 7, 2009 | 10:16 AM
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Re: t5 Question
JamesC
ok, well it seems the only part that is weaker in the v6 T5 is the input shaft. couldn't he swap input shafts and bell housings still though???
Old Feb 7, 2009 | 11:54 AM
Re: t5 Question
The V6 bellhousing is going to be different. I think the 3.4 bellhousing is deeper than the 2.8 bellhousing. It's been about 12 years since I built my truck and I can't remember what parts were different. I know I couldn't use the 3.4 bellhousing, flywheel or clutch in my S10. The 3.4 flywheel is much thicker than the 2.8 flywheel. I had to use the S10 T-5 too. The bolt pattern on the 3.4 bellhousing is going to be way off on the 5.0.
Why not rebuild the original transmission?
Old Feb 7, 2009 | 12:20 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: t5 Question
the clutch is smaller, and i think the input shaft at pilot bearing is longer, other than that, i would think you can use it, or just get a wc input shaft and install it in the v6 tranny
Old Feb 7, 2009 | 02:38 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: t5 Question
the info about the case being different can be found here http://www.flatheadv8.org/ernie/ernie-t5.htm
Old Feb 7, 2009 | 02:42 PM
JamesC's Avatar
Re: t5 Question
Part of the T5 sticky.
JamesC
Old Feb 7, 2009 | 04:14 PM
Re: t5 Question
So the '93 and later GM T-5 transmissions do have the Ford bolt pattern. It was probalby cheaper for GM to buy them that way.
Old Feb 7, 2009 | 06:54 PM
Jairo's Avatar
Re: t5 Question
so i guess the best to do is take it apart and compare huh..
ill just do that. thanks for all the input guys.
if it dont fit, the'll be a t5 tranny in the for sale section soon
Old Feb 7, 2009 | 07:56 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: t5 Question
The 4th gen and Mustang T5's install straight-up/plumb. The 3rd gen T5's are clocked at 17 deg clockwise (when viewed from the rear of the trans). Third gen bellhousings are unique.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
