700r4 shifts early and extra shift??
Old Feb 7, 2009 | 02:45 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
I have a 1985 IROC-Z with an lb9 TPI and 700r4. The transmission is shifting a little early and it seems like it shifts an extra time? I know that's impossible, but that's exactly what it feels like. When I have the shifter in 1 or 2, it doesn't do this, but when i put it in Drive it acts like it's shifting a total of 4 times and when it's in overdrive, a total of 5 times.
It only does this after I have been going down the road for about 2-3 minutes. It cruises about 500 rpm less than It does in overdrive and it actually feels like there's a miss. I'm thinking the Overdrive solenoid located on the transmission is malfunctioning.
Please help me.
Old Feb 8, 2009 | 11:31 PM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: 700r4 shifts early and extra shift??
if the engine feels like it's missing it probably is. the trans is stupid and only locks or unlocks t.c.c. while cruising in fourth(and possibly third in models with a third switch on the valvebody). the rpm drop is normal but the engine missing is probably just that-an engine miss. you probably notice it more because the engine will bog some and causes an additional load to the engine making the miss more noticeable. correct me if i'm wrong.
Old Feb 9, 2009 | 04:48 PM
Car: 1985 IROC
Engine: lb9
Axle/Gears: 3.42s
I'm positive it's not an engine miss. The torque converter is choosing to slip for whatever reason. I need to determine if it's a faulty converter or a problem dealing with the tc choosing to lockup/slip. How could I eliminate the tcc lockup solenoid?
Old Feb 10, 2009 | 12:36 AM
ed o's Avatar
Axle/Gears: 3.36
disconnect the connector on the drivers side of the transmission
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
