tranny won't go in reverse
Old May 13, 2001 | 10:33 AM
87 IROC 350 TPI's Avatar
I have a 90 IROC when first started engine cold it won't go in reverse untill it run's a couple minute's. after that it's fine till it sit's parked awhile. everything else seem's to be working fine. It goes right in foreward gear's all the time. The Tran's.Is a 700R4. Any help would be appreciated.
Old May 13, 2001 | 11:41 AM
transfixleo's Avatar
The 700 of that year uses a feed-bleed system (a controlled leak) that doesn't seal until reverse fully engages. With age and wear this starts to act up, although usually when hot. This can't be corrected in car. WHen it is O/H'ed this arrangement can be modified to correct this problem.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
