Console on my firebird set up for 3speed tranny,Will 4 spd shiftplate/shifter work?
Old May 13, 2001 | 11:13 PM
firebird305's Avatar
My car originally came with the 4cyl/3speed tranny set-up,It now has a 305 and 700r-4 I would like to change my shift plate to one that has the space for overdrive,And maybe even update to a b&m shifter,But i've been told that even if i change the shifter plate and shifter,I still won't be able to use all the gears because the metal brace that the shifter sits in is set up for the old 3 sped tranny. Is this true,And if it is,What do i have to do to fix it?
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,ASP power pully.
Old May 13, 2001 | 11:18 PM
82camaro's Avatar
Car: 82 camaro SC
I installed a B&M megashifter in my 82 without any problems. I installed in when I put in a 700r4.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
