rear end ratio?
Old May 14, 2001 | 02:42 PM
Metalman's Avatar
rear end ratio?
I'm not sure what my axle ratio is. Is there a ref. to axle codes I can look up on the internet? From what I could tell from the RT. FRT. axle tube is 2JG C064 2 The RPO code that came in the car from the center console lid is GT4=3.73 The VIN matches But I've never seen 2JG to go with that year, 84 Z-28 HO, 700R4, drum brakes. If anybody has a reference I can look up I would appreciate it.
Old May 14, 2001 | 06:55 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Well, from what I know a JG is a 3.08 ratio open rear end. Bookmark this site, it is the best site for camaro info (1st three gens). That diff. is not the original.
George P. Lara
3rd Gen, 4th Gen
SCCA, SCFB, SC3GFB
Old May 14, 2001 | 07:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
He's right, 2JG or just JG is a 3.08 "peg-leg" differential. That doesn't mean the gears havn't been changed though.
An easy test is to drive the car w/ the tranny in its 1:1 gear ration (3rd or (D) for a 700, 4th for a 5 speed) and cruise at 70MPH. See what your RPMs are, and put a decimal point after the first digit of your RPM and thats approximatly your ratio.
Example:
2.73= 2700 rpms
3.08= 3000
3.73= 3700
4.10= 4100, you get the picture.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
