how hard to change over to disc?
Old May 14, 2001 | 12:59 PM
Zio's Avatar
Zio
Ok guys I have an open 2.73 rear end right now and it has drums. I want to just swap out the whole rearend. I am looking for a rear with 3.42s, but most of them that i have seen are disc set-ups. What needs to be done and how hard is it to switch over to disc brakes in the rear? also is it worth it to switch to disc or should i stay with drums?
thanks
Tom
Old May 14, 2001 | 07:43 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its not hard at all. All you need is the complete rear, new E-brake cables for the J65 brake option, and a new combination valve (aka proportioning valve) also for the J65 option. Check this link out: <A HREF="http://sethirdgen.org/10boltinstall.htm" onMouseover="window.status='Click me you Bastard!'; return true" onMouseout="window.status=''; return true"> Rear Swap </A>
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
[This message has been edited by GMTech (edited May 14, 2001).]
Old May 14, 2001 | 08:41 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Hey GMTech, that link doesn't work! I'm asking the same question as Zio, so hook us up!
Old May 14, 2001 | 09:58 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Sorry, I wrote the link using JavaScript (just having fun! ) and I messed it up, alot more code than UBB or HTML. Try it again.
P.S. check your status bar before you "click" the link! L8tr
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old May 15, 2001 | 01:43 AM
jaretz28's Avatar
Grab a friend couple beers, should take you no more than an afternoon (with the right tools)
maroe624
Apr 16, 2017 08:29 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
