convertor lock up question?
Old Feb 10, 2009 | 02:34 PM
THE HOFFMEISTER's Avatar
Car: 89 Trans Am GTA
I have just read the tech article on here about installing a
switch to lock the torque convertor manually.
Claims it helps performance, but.....
on so called performance chips, they change the programming
to delay convertor lock up, which kinda goes against what
the switch will do for you.
So.. what is best for performance, delaying lock up like
on the chips, or
using a manual switch (like in article)to lock it up earlier?
Bit confused here, so could you enlighten me into
whats best?
Old Feb 10, 2009 | 06:04 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: convertor lock up question?
I think the main reason they delay the lockup is for driveability. The way mine was set up factory, at about 40mph the converter would lock and unlock constantly which was annoying. Most chips are programmed to a little faster speed to avoid that.
I've heard locking up the converter in second gear can be good, because you don't have the power loss through fluid coupling. My friend locks the conv. on his Turbo Buick in second and usually picks up a few mph in the 1/4. I think though if its a stock converter it may eventually damage the lockup clutch. Aftermarket converters usually have a heavier duty clutch in there.
Old Feb 11, 2009 | 12:24 PM
Yea, it would probably wear the thing out, but do you think i
would get away with it, if it was just used occasionally, like
the odd time its taken to the track.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Cameeeero
Sep 18, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
