posi carrier question
Old Feb 11, 2009 | 12:51 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
I am looking for a posi unit for a 7.5 innch ring gear 10 bolt im building. Are all GM posi carriers compatible with different ring gear sizes or do i have to have a 7.5 specific carrier?For example, will a carrier for a 8.5 ring gear 10 bolt fit a 7.5 ring gear 10 bolt?
Old Feb 11, 2009 | 06:34 AM
big gear head's Avatar
Re: posi carrier question
It must be for the 7.5 and it must be the correct series for the gear ratio that you will be using. The 3.08 to 2.41 used a 2 series and the 3.23 to 4.10 used a 3 series. It also must have the correct splines for the axles that you will be using. Before '90 they were 26 splines and after that they were 28 splines.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
mcgarnicle
Aug 12, 2015 04:58 PM
knight72
Aug 10, 2015 09:32 PM
