noise when i press clutch
Old May 17, 2001 | 01:22 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
hello, i have a camaro 87 350 carb, with a nwcT-5, and 2 days ago started to sound like grinding when i press the clutch (at random)soon as i release the pedal and the car starts moving it dissapears for a while, only sometimes when i stop and try to get 1st or reverse i got that sound and also makes kinda hard to shift, could it be the throw-out bearing?
thanks to all.
fernando.
third gen muscle power is the only thing that can match the power of flight...
Old May 17, 2001 | 03:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That would be likely.
ICON Motorsports
Old May 17, 2001 | 10:22 PM
82z's Avatar
82z
It could also be your pilot bearing. What happens when you push the pedal down far enough to make the t.o.b. hit the release fingers but not release the clutch?
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old May 18, 2001 | 01:40 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
actually its getting worst, it grinds now at all times and i can still hear it in 5th. gear. oil is fine (full) sounds like something is getting a lot of play, or bearings or gears about to go.
is there in the market an overhaul kit i can buy?
thanx...fernando
Old May 18, 2001 | 01:52 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
actually i have another T-5, but from a v-6, sure the input shaft is smaller, but i wander if the rest of it could be the same?
i mean the internal parts?
thanks again...
fernando
Old May 18, 2001 | 10:07 AM
BigChevy342's Avatar
The tailshaft yoke might be different
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
