Vibrations!!
Old May 18, 2001 | 07:48 PM
SpeedinTA's Avatar
Car: 1989 Firebird Formula
Engine: 305 ci
Axle/Gears: 2.73 for now
Vibrations!!
I now have a n 89 formula, 305 auto, I previously had a 1986 trans am, 305 auto, both cars vibrate badly! mostly felt in the seat, not the steering wheel. changed driveshafts on both and balanced all wheels to no improvement! Vibrates terribly from 50 to 85 mph. any ideas? thanks
Tim
Old May 18, 2001 | 08:42 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Hey,
Sorry if this is too elementary for you but...It sounds like either misbalanced tires or a flatspotted tire to me. If it's only noticable at the higher speeds, I'd check the wheel balance first. You can notice a bad flatspot as soon as you start rolling. Either way, You've gotta love it when that dashboard gets to dancin'
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old May 19, 2001 | 12:35 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Ive got the same problem with my 85 bird.
Changed to alum.driveshaft
changed both half shafts
complete new suspension including all bushes
hotchkiss panhard rod and trailing arms
New WHEELS AND TIRES
Different engine plus new trans and convertor
Subframe connectors and strut brace
Vibration still exactly the same
Powermite
Old May 20, 2001 | 11:00 AM
stephenc's Avatar
i had a very annoying vibration right at 80 MPH (the vibration drops off considerably below 78MPH and above 85 MPH). rebalancing the tires did not seem to help. replacing all four tires did do the trick, and it was about time for new tires anyway.
stephen - 89 GTA - https://www.thirdgen.org/rides/index...ew&rideid=1321
Old May 20, 2001 | 04:10 PM
Sandy Mandel's Avatar
I had vibration problems too when I switched to 3.73 gearing with my T-5. Rebalancing the driveshaft got rid of most of the vibes. But, one thing to consider is that drive shaft vibrations are about 2500Hz or times per second, where tire/wheel vibration is about 750-800 rpms. The feeling is very different. The higher freq vibration feels like a 'drumming' sound. Where the wheel misbalance or tire carcus distortion can make the steering wheel shake back and forth. Also, a bad spark plug wire/miss fire can also feel like a vibration problem....
Old May 20, 2001 | 05:08 PM
89camarotpimonster's Avatar
i have the same problem, my vibration starts around 60 mph and get worse on up till about 80, 85mph then levels out. havent found it yet, but i can tell you this. i have new tires had all rims balanced and it still does it. i found that my transmission mount was bad and am in the process of changing it. hopefully this fixes it. good luck.
Old May 20, 2001 | 05:19 PM
maksik7's Avatar
To StephenC
What is the name and color code for your car. That color looks awesome. I am about to get my silver TA repainted and I think this might be the color. How much did it cost?
Please E-Mail me with response...
Sorry about being off topic. I don't know what all you people are complaining about. My car shakes, vibrates, jumps,bottoms out, and has a loud exhaust... that is the whole fun of owning a Domestic v8 and scring the Sh*t out of pople you pass by
-Max
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
