Ring gear size
Old May 20, 2001 | 01:34 PM
bigdaddy's Avatar
Ring gear size
I need to know what size ring rear I have in my 1987 Trans Am GTA. Is it a 7 1/2? Same as a Camaro? It has the rubber plug in the back cover to fill. It is also stamped 3.21 ratio and not 3.27 the way everybody says they have. Also will I have to have an adapter plate to install a 4.10 or 4.11 ring and pinion?
Old May 20, 2001 | 03:04 PM
82camaro's Avatar
Car: 82 camaro SC
If it has the rubber plug, it's a 7.75 inch 9 bolt. Good luck finding parts.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 20, 2001 | 10:52 PM
jaretz28's Avatar
If ya go a nine bolt, and what to ever change gears...change the whole rearend cause 3.73 and 4.10 gears are upwards of 400 - 600 buckS !!!! That's if you are lucky enough to find them.
Old May 21, 2001 | 12:45 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Not sure about the 3.21 ratio, but it sounds like a 9 bolt to me. Pull the diff cover and see what is says on the side of the ring gear.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
hectre13
Dec 11, 2023 08:14 AM
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
gixxer92
Sep 1, 2015 04:32 PM
knight72
Aug 10, 2015 09:32 PM
