question about powertrax
Old May 21, 2001 | 04:58 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I ordered mine from summit last week, so it should be here anytime, my question is
does powertrax need be filled with any kind of special fluid?
can I just use normal posi gear lube?
probably a stupid question
Old May 21, 2001 | 05:24 PM
82camaro's Avatar
Car: 82 camaro SC
Just regular lube(not posi lube). the posi type lube is for the posi clutches, the powertrax has no clutches. IMO, synthetic is the way to go. It doesn't cost much more(you only need 2 quarts and you won't have to change it as often), it reduces wear, and lasts longer.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 21, 2001 | 07:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ditto. The PowerTrax instructions don't say anything about a posi lube or a posi additive. Synthetic absolutely the best way to go.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Americanmouse
Sep 7, 2015 12:10 PM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
