my car has a posi and not sure what axle ratio was.how can I check it with out pulling the diff cover off?
JamesC
close
Quote:
IMO, without yanking the cover, you can't really be positive.Originally Posted by my90bird
my car has a posi and not sure what axle ratio was.how can I check it with out pulling the diff cover off? JamesC
This is true, but you can get a rough idea of what it is by counting the drive shaft revolutions. If it has a posi and it is in good working condition then try this. Raise the rear tires off of the ground and put the transmission in neutral. Mark the rear tires in the 6:00 position. Have someone else watch one tire while you turn the other. Mark the drive shaft where you can see it. Turn the tire exactly one full revolution. Have the other person watch the other tire to be sure that it also turns exactly one revolution. If it doesn't then this will not be accurate. Count the number of times that the drive shaft turns. If it turns just over 3 times then it is a 3.08, if it turns 2 3/4 times then it is a 2.73, if it turs 3 1/4 times it is a 3.23, if it turns just short of 3 1/2 times it is a 3.42, and 3 3/4 times would be a 3.73.
have you tried checking for the RPO code in the center console? just a thought assuming you car is completely stock, but yea pulling the cover would be the surest way to tell........
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
GU6 = 3.42
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
GU6 = 3.42
thers a code on the passenger side of the axle on the tube on the front u will have to clean it off with a wire brush or something like that a 3 digit code then you can check it with the haynes manual
JamesC
close
Quote:
The codes are generally rusted beyond recognition. Like the RPO's, they only reveal what was in the car new, not what might be lurking inside the diff housing at this late date. However, here's a link that provides those codes:Originally Posted by jeffj30
thers a code on the passenger side of the axle on the tube on the front u will have to clean it off with a wire brush or something like that a 3 digit code then you can check it with the haynes manual http://sethirdgen.org/reardata.htm
JamesC
well i got mine off my 87 i live in snowy alberta canada
JamesC
close
Quote:
Lucky man.Originally Posted by jeffj30
well i got mine off my 87 i live in snowy alberta canada JamesC
1brd2brd3brd4
close
- Join DateDec 2006
- LocationEvington,Va
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car93 Formula,88 T/A,01 WS6
- Engine93 LT1,88TPI305,01 LS1
- Transmission93 700R4,88 700R4,01 T56
- Axle/Gears93 3:73's,88 3:42,01 3:40
- Liked:0 Times in 0 Posts
Just pull the cover,its not hard to do and it probably way over due for a gear oil change anyway......dont forget to put in limited slip aditive!
