cooler line ?
Old Feb 15, 2009 | 03:56 PM
da_jester's Avatar
Car: 1992 camaro rs
cooler line ?
my transmission lines broke the ones for the cooler in the radiator so i want to replace them.but do i have to buy a 20 ft roll of line or does anyone know how long they are? if like a 60 inch piece will replace the hole thing i need to do both of them.
Old Feb 15, 2009 | 08:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: cooler line ?
They're just standard brake lines like you can pick up from your local auto parts store. Uses the same ends. 60" is the longest premade line. If it's not long enough, just put a union in and add a second piece.
Old Feb 15, 2009 | 09:11 PM
da_jester's Avatar
Car: 1992 camaro rs
Re: cooler line ?
i was just wondering if any one knew how long they wereand cant you get 72 inch lines?
Old Feb 15, 2009 | 11:06 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: cooler line ?
usually shops get brake lines in bulk on big reels....like the reels of cut-to-length hose @ the hardware store. they basically cut however much they need, add fittings, and flare the ends and there ya go. try to find a place that sells brake line that way or ask around @ a few local shops and see if they'll sell you some. it's worth a shot.
Bubbajones_ya
Jul 6, 2024 08:32 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
tommy z-28
Oct 6, 2015 10:58 PM
TBRays98
Sep 6, 2015 05:05 PM
apie2546
Sep 5, 2015 07:40 PM
