3.42 rear VSS gear 19 or 20 tooth
Car: 1989 Firebird
Engine: 2.8
I did the 700r4 to T5 swap and after a big headache I found a speed sensor for it. Through my searching I have found two gears for it and I was wondering witch would be better to use. I have a 3.42 rear end and the two gears I have are 19 tooth and 20 tooth. Witch would make my speedo more accurate?
Thanks,
Chuck
I'm not shy, I just
observing my prey.
My Firebird site
Thanks,
Chuck
I'm not shy, I just
observing my prey.
My Firebird site
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Depends on your tires, but stock is the 19 tooth. The 20 tooth is for 3.70's with larger than stock tires.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 1989 Firebird
Engine: 2.8
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
</font>
thanks!!
[This message has been edited by birdofprey83 (edited May 22, 2001).]
Only if you have 28" tires. For stock 25.5" or 26" tires, the 19 tooth works well for 3.42 or 3.45 gears.
novaderrik
Aug 10, 2015 12:44 PM
