T5 w/ 350 motor
Old May 22, 2001 | 09:06 PM
allrog214's Avatar
T5 w/ 350 motor
I read some where that a T5 tranny isn't strong enough to handle a 350ci motor, and that you should or have to use a T56 tranny. Does this claim hold true?
Old May 22, 2001 | 10:51 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
It's true if you don't know how to drive and be friendly to the 5 speed
if you abuse it, it will die
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old May 23, 2001 | 05:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I have my stock T5 behind my ~500 TQ TPI engine, and so far I've had to replace the 2nd and 3rd gear synchros, and the gears themselves. If you race it, it'll break, but I'm sure if you just drive it around normally, it'll work for a very long time.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 23, 2001 | 07:01 PM
F22Raptor's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
Kevin, are you still using the 52mm TB....do you feel you might need a 58mm?
Thanks, Rick
Old May 24, 2001 | 01:31 AM
Kevin91Z's Avatar
Nope, its my belief a 52mm is fine for a long-runner TPI intake. You only need a 58mm if you're running nitrous, a blower/turbo, or if you have a SuperRam or MiniRam.
Old May 24, 2001 | 01:46 AM
IROC KID's Avatar
If you have the borg warner world class t-5 then you should be fine,the wc t-5 is stronger.
www.rearman.com/camarokid.htm
If it aint a V-8 that $hit aint fast!,unless its a GN,lol!
305 tpi,700r-4 with shift kit,My mods are minimal,just a bunch of little $hit.Anyone know where to get underdrive pulleys for a v-belt set up?
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
