Identifying gear ratio......Help
Subscribe
May 22, 2001 | 12:38 PM
I can't seem to find any #'s on my rearend axle housing,either side.Where do I need to look and how many #' will it be so I know what to look for?I would like to know what gears I have.I run around 2200-2500 at 70MPH I beleive.I don't think they are to low cause I only smoke em for about 20 feet from a dead stop then she just goes and she don't bog after the tires bite either.
Reply 0
May 22, 2001 | 01:56 PM
Don't waste your time with fiddling around the numbers. Just pop the cover off and look. If you haven't changed the fluid lately it needs that done anyway.
ICON Motorsports
Reply 0
May 23, 2001 | 06:11 PM
What kind of car do you have? If the rear end is stock you can look on the tech database on this site and it can tell you. Is that 2300 RPMs in overdrive or drive, at 70 MPH? You have to check it in drive.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Reply 0
May 24, 2001 | 07:38 AM
i agree with rb pull the cover count teeth or find the ratio stamped on the gears, change the lube and posi additive.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Reply 0
Subscribe
