Stuck pinion shaft bolt...HELP
Old Feb 17, 2009 | 08:30 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I tried removing the pinion shaft bolt on a rearend I'm rebuilding and I rounded the *&%#!!! bolt head. I used a 6pt box wrench and socket, but cracked the socket and rounded the head. I've torched it with MAP gas, drilled a hole thru the side of the head in hopes I could insert a punch thru it and wack it with a hammer but all I do is break/bend punches and throw stuff! This isn't gonna beat me! Any suggestions are greatly appreciated.
Old Feb 17, 2009 | 08:38 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: Stuck pinion shaft bolt...HELP
Go to your hardware store and buy one of those nut cracker things. Its like an oversized socket you wack on with a hammer and it has teeth that grabs the rounded bolt then you just take it off with a big wrench. I remember when i took out my pinion i had a shop use air tools to take it off cause the damn thing wasnt moving.
Old Feb 17, 2009 | 08:57 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
thanks....hopefully there's one that will fit. I have a rounded bolt remover set but it's too big 4 this bolt.
Old Feb 17, 2009 | 09:09 PM
big gear head's Avatar
This bolt is in a tight place and it's hard to get to it. I think I've used a chisel before to break them loose. I have a special 6 point wrench that I use because I rounded off a few with a 12 point.
Old Feb 18, 2009 | 01:57 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
use an electric impact if you don't have access to the proper air supply. you can rent a real heavy duty one from a local rental. use a 3/4 incher with a reducer to 1/2 and use your broken socket. weld the socket to the nut carefully with a tack on all sides.
just some random thoughts.
Old Feb 20, 2009 | 01:35 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Thanks guys....I had success with blasting the bolt/casing for about five minutes with a torch til the bolt was cherry and then stuck a small phillips head thru the hole I drilled and gave it a wack and it busted loose.
tmellott89
Oct 14, 2015 02:06 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
6998poncho
Sep 25, 2015 02:56 PM
