1984 Z28 rearend
Old Feb 18, 2009 | 11:28 PM
AKATDOG's Avatar
Car: 84 Z28
1984 Z28 rearend
i want to put a posi unit with 373 or 355 gears in my rearend, can someone point me in the right direction ? Thanks
Old Feb 19, 2009 | 07:01 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 1984 Z28 rearend
Find a 90-92 rear with better rear brakes , limited slip and 3:23 or 3:42 ratio. These are 10-bolts with 28 spline axle shafts.
Old Feb 19, 2009 | 07:04 AM
big gear head's Avatar
You will need a 26 spline Eaton posi. an installation kit and a set of gears. There are no 3.55 gears for this rear end. Your other option would be a 3.42. Send me an email or PM if you want prices on the parts.
Old Feb 19, 2009 | 03:20 PM
AKATDOG's Avatar
Car: 84 Z28
90-92 will this bolt straight in ? and should i go with 342 or 373 gears ? thanks.
Old Feb 19, 2009 | 03:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes.
With a 700R4, probably 3.42's.
JamesC
Old Feb 19, 2009 | 03:45 PM
AKATDOG's Avatar
Car: 84 Z28
Originally Posted by JamesC
Yes.
JamesC
ok so 90 to 92 and doesnt matter on model ? and whats the benefit of 342 over 373 gears ? Thanks for the info
Old Feb 19, 2009 | 04:04 PM
JamesC's Avatar
Model doesn't matter. Decide for yourself:
https://www.thirdgen.org/forums/tran...42-3-73-a.html
JamesC
Old Feb 19, 2009 | 04:21 PM
DJP87Z28's Avatar
You will NOT find any stock 3:73 gear ratio in any 90-92 rear axle assemblies.
Old Feb 19, 2009 | 05:08 PM
JamesC's Avatar
True enough (IIRC, OE 3.73's ended with the L69 in 1986). Any model 90-92 will bolt in, of course. He can, however, throw whatever gears that he wishes into his current rear. The link may assist in that decision.
JamesC
Old Feb 19, 2009 | 08:06 PM
AKATDOG's Avatar
Car: 84 Z28
thanks guys that user has a little diff setup to mine, i have a 350 with upgraded cam, lifters, intake, headers, exaust and a 650 carburetor with an auto 700r4 trans, anyone with a similar setup can point me to what gears im looking for, i also do a fair amout of highway driving...
Old Feb 19, 2009 | 08:29 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
I would think that if you have a lot highway driving then you would want the the 3.42's. You'll probably get crappy gas mileage with either set of gears but better with the 3.42. It all depends what you are looking for.
Old Feb 19, 2009 | 08:38 PM
AKATDOG's Avatar
Car: 84 Z28
thanks ya it looks like the 342 are better for all around driving, ill have to start with that, thanks everyone for the info
Old Feb 19, 2009 | 08:41 PM
I've got a good set of used GM 3.42s. I sell used gears for $50 if you are interested.
Old Feb 19, 2009 | 10:22 PM
AKATDOG's Avatar
Car: 84 Z28
will a 28 spline posi(out of a 98 Camaro v6 auto) with 3:42 gears bolt into my rearend if i get a set of 28 spline axles from a 91 or 92 ? and how much would the axles cost cost approx. ? Thanks
Old Feb 20, 2009 | 07:08 AM
Yes, all you would need to do is install 28 spline axles. You could get a set from any '90 to '92 Camaro or Firebird.
Old Feb 20, 2009 | 07:21 AM
JamesC's Avatar
Both Moser and Superior sell new, if that's a route you're comfortable with. IIRC, I paid $235 or so from Summit (you'll also need wheel studs). You might consider replacing bearings and seals as well.
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Old Feb 20, 2009 | 09:03 AM
Always replace the axle bearings and seals when installing new axles.
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Saxondale
Sep 15, 2015 06:42 PM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
funkyTA
Sep 10, 2015 06:38 PM
84 TA NV
Sep 6, 2015 08:02 PM
