wich converter for this cam?
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
hi,what kinda of converter should i look at
487-508 lift 234-244 at .50 at 112
89 bird 3450lbs with me in it
3.73 rear
383 stroker
9.5 to 1 comp
750cfm carb vacuum sec
i would like it to be steet friendy if at all lol
thx
3.73 rear
383 stroker
9.5 to 1 comp
thx
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: wich converter for this cam?
What camshaft is it?
OK, found a Comp Cams with similar specs to what you've provided so far. For street or street/strip, you'll want a converter that stalls around 2900 rpm.
1992 Trans Am
May 10, 2023 07:19 PM
