Converter: Lock Up vs. Non Lock Up?
Old May 30, 2001 | 09:06 AM
Changa2's Avatar
I'm just about ready to drop a 383 into my 87 Camaro but I want a 2500 to 2800 stall converter before I begin. This will be mostly street driven, but not our primary wheels.
In checking numerous web site catalogs I see where they offer both Lock Up and Non-Lock Up converters for the 700 R4.
(My ignorance is showing but)Is there any reason I would even consider a Non-Lock Up? Just for a better understanding why would anyone, with a 700 R4?
I will be eliminating most, if not all the ECM and computer controls. Is conveter lock-up controlled from within the Trany or some external electronic wizardry?
Thanks.
[This message has been edited by Changa2 (edited May 30, 2001).]
Old May 30, 2001 | 06:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you have a choice, the lockup is a very nice feature to have on the street, especially with a high stall convertor. The only reason not to have it is the lower cost of a non-lockup convertor, but you'll eat up the savings with reduced fuel economy over time.
The lockup is controlled by the computer providing a ground path to the lockup solenoid (although the internal fluid circuitry won't allow lockup in 1st). There is also a switch on the brake pedal that interupts power to the solenoid when the brake is depressed. If you are eliminating the ECM, then get a lockup kit that is available from either Summit or Jegs.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
