speedo gear for 4:10s
I just swapped from an open 2:73 rear to a limited slip with a 4:10 ratio. now my speedo reads 100 mph at 70mph. I'd like to have an accurate speedo again. i'd also like to go over 80 every so often. Since I can't seem to find an aftermarket chip I still have the speed limiting governor.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo gear for 4:10s
JamesC
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
If it's a 700R4 you need the 15 and 45 tooth gears. I just put 4.11's in my 9". It's not spot on, but you'll be within 5mph though... on the slow side(I think).
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
