Ring gear size
Old Jun 3, 2001 | 10:28 AM
bigdaddy's Avatar
Ring gear size
Does anyone have a ring and pinion set to fit 87 T.A. GTA ring gear is a 7.75" real odd ball.
Old Jun 3, 2001 | 11:22 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A 10 bolt is 7 1/2" or 7 5/8". A Borg Warner 9 bolt is 7 3/4".
9 bolt ring gears are hard to find. Some gear suppliers in North America carry them but the best choice is from Australia.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jun 3, 2001 | 11:29 PM
AFRO IROC Z's Avatar
Strange engineering has a ring gear for your 9-bolt. The thing is is that it is a 3.70. If you wanted to put better gears in, well, here you go. This is the only after market gear made for the 9-bolt, it cost 320.00 dollars. Other than that you can go to the dealer I think they want over 400.00 bucks. They have the stock gears if you really want them, if not give strange a call they have the install kit as well. It's a pretty strong gear capable of handling more horsepower than the stock one.
hectre13
Dec 11, 2023 08:14 AM
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
gixxer92
Sep 1, 2015 04:32 PM
knight72
Aug 10, 2015 09:32 PM
